location of camshaft position sensor
SHOemup
Dalton, PA
I think if you remove the power steering canister (you dont have to disconnect hosess) you can see the two bolts that hold it on. Im not definite but for some reason thats where i think it is.
fredhurderjr
www.neshospecialists.com
Chris has it right. The Cam Position Sensor is a black plastic circular piece about 2.5" in diameter with 2 bolts holding it to the rear head exhaust cam (farthest toward the firewall). It is on the passenger side, behind the power steering reservoir.
The CID sensor is just left of center in this photo. The 5.5mm screws can also be removed with a more common 7/32" socket.
<small>[ October 25, 2003, 10:33 PM: Message edited by: sdpatt ]</small>
