Lincoln MKZ torque vectoring differential
ArthurUSCG
Southern MD
I brought it up in another post, but the Lincoln MKZ has a torque vectoring differential similar to the Focus RS. From what I can tell from the part numbers, the IRS sub-frame are the same for all of the AWD Fusion and MKZ variants, so the mounting points for the differential should be the same.
I haven't had the chance to look into wireing, I'm not sure if the TV diff can be pluged into or work with the VC diff wireing and ECM.
Ta2dResqr
Central Ohio
Are you trying to ask if the MKZ/Fusion stuff transfers to the MKS/Taurus? I would not expect it to, based on the CD3 vs. D4 platform, 3.0 vs. 3.5 motors, and 6F35 vs. 6F55 transmissions.
