Lincoln LS Wheels?
silky
Vero Beach
I have a chance to pickup a set of 17X7.5 Factory wheels off a Lincoln LS. Will they fit my 1995 SHO? Thanks for your help.
Bluto
Rochester, NY
I don't know all the detailes but the offset is off a hair. The pattern is fine.
A fella named Drew mentioned it at a meet. He has some. Maybe he will chime in if he is on the forum.
ohioshodude
SHO'ld fogy
delaware, ohio
with massive spacers they will work, same bolt pattern but they have something like a 55-60mm offset way too much for a sho. but with a 17-20mm spacer they would work. (spacer would need new lugs, or the hubs would need much longer lugs) i'd like to see it done. thumb
silky
Vero Beach
Thanks for the help. Why is it that all the good deals won't fit my car?
pjtoledo
'ol man in the SHO
toledo,ohio,usa
silky:
Damn, where have we heard that before??
Welcome to the club. There isn't much of a selection for us.
Perry
GreenBird
Barre, Vermont
You could have the whells changed to have the correct offset. Basically you gas or TIG (MIG isn't as strong) weld a solid aluminum spacer directly to the wheel, and then use a tire balencer to re-balence the wheel.
Very expensive thing to do, but you'd be unique for sure!
