light on temp control blinking
79svt
Northern Al.
On my temp control display it blinks when I put on the emg.flashers or when I use the turn signals, it is the same speed as the lights. Also when I have the autolamp on at night the radio stays on till the headlights go out. Any help here????????? Thanks Frank 92 black Sho
Bizzy
79svt:
Sounds like you have 2 separate issues here. One sounds like someone wired the climate control to your turn signal relay. Do the lights actually flash, or do they just go dim and then bright with the lights? Either way, that's strange and I'm not sure what to suggest.
The other issue sounds like your radio is wired into the fuse for your headlights. You can either re-wire it to a different power supply or just turn your autolamp switch off when you park the car so that the radio goes off then. I personally would re-wire the power supply.
