Okay, thought I would post this here, since my problems do not stem from the tune (in the form of the Tweecer) or my turbo system.
Here is a brief history: When I first got the car running, my 90mm MAF was wired backward. So the EEC was reding a full voltage at all times. CE lights on, MAF codes, etc, but the car ran decently enough, so that I drove it on a 140mile trip, and got 20mpg. Still, it was far from perfect, and I knew it needed some changes. Well, once I datalogged it and saw my MAF values (DOH!), I wired it up right and took it for a spin. WOT was AMAZING, car was very quick, all readings looked spot on and no CE lights, no codes.
But for some reason, I could not drive the car part throttle. Try and cruise for 5 seconds and my WB was looking like an oscilliscope (sp?), car would lean out and try to die. Well, it seemed my old fix to a HEGO was no longer working (wire had melted once, I rewired it, but it needed a new one). Well, I had a new harness, wired it in, got two new HEGO's, and went to town. Now the HEGO readings were where they should be. A full datalog showed my LAMBSE and KAMRF values were what you would expect, all other values good as well, but still the part throttle leaning out.
This is what I know, MAF read correctly, TPS is new and reads correctly, car has the air/spark/fuel to make made power, and runs awesome once in WOT, but awful in closed loop. This is what has been replaced with the last turbo swap: turbo, BOV, WG, trans, halfshafts etc. All of those of course not having an affect on my problem. BUT, I also removed the FMU, added the FPR (and yes, fp checked out great), removed CC, and rerouted a number of vacuum lines.
So, cliff notes: WOT = great, part throttle = crap - car leans out and dies within seconds. No CE lights, no codes. Idles good (though it take a while for it to drop below 17:1, is this normal?), datalogs from Tweecer give no evidence of a problem. My question to the forum, what is the problem? What would only present itself @ part throttle, but let the car run amazing @ WOT? I await your answers (and as always, a prize for the problem solver, how does driving the turbo at Memphis for a few laps sound?).
