KYB and Eibach Springs - compatability
Arc Angel
Arc Angel
PA
Hey SHO Guru's...quick, although admittedly, probably stupid question -
I found a 1st gen SHO (just sent to the junk yard after an accident) with what looks to be nearly brand new Eibach Springs and KYB gas struts. No kidding; they look like they were installed maybe a week, tops. My question - will 1st Gen Struts/Springs mount into a 2nd Gen SHO?
Thanks in advance for any reply. If they will mount, I'm grabbing them. Just picked up another 94 White SHO ATX, and these look perfect - if they'll fit, I'm grabbing them.
Frank
Ishodu
They will mount in either gen. But those struts won't last with lowering springs.
SHOpoor
New Jersey
I just took an almost new set of KYB's OFF of my wife's ATX. They are just too soft and won't hold up with the Eibachs. The valving can't handle the spring response of the Eibachs. If you can get them for the value of the springs, go for it, but expect to buy some struts pretty soon.
Arc Angel
Arc Angel
PA
Thanks for the answers, as it is much appreciated! Yea...I'll grab them, then - for $15.00 (yes - fifteen dollars) each (all four for sixty bucks), I really can't go wrong.
Frank
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Frank
Listen, those will NOT fit your SHO. However, they'll fit mine perfectly. So send them over here. . . . . . :evilgrin:
crystizel
