philw349
PhilW
Ok I've heard how easy it is to install the Koni's into the stock casings, and now I need a tip I guess. I've got the struts out and I'm ready to put it in. Question is, can I use a cutting wheel to cut the end off the stock casings? If that works then all I need to do is drain the oil and insert the strut correct? Thanks, just making sure it will work. I have a friend over helping and he seems to think its a lost cause before we even start. This is not too hard right?
