Tomuza
I'm not sure what codes 14 and 19 mean... would someone please explain these and provide some insite to possible fixes.
\Shotimes faq page/
code 14= PIP circuit failure. Suspect PIP sensor or TFI module, or grounding or interference problems at the TFI module.
code 19= CID circuit failed.
\from the alternate code site/
code 14= Ignition pickup was erratic - Ignition Systems
code 19= O) No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
(R) Erratic idle during test (reset throttle & retest) - Idle Set Procedures
Electronic ignition Cylinder ID sensor/circuit problem - Ignition Systems
90 mtx 150+k
Thanks, Tomuza
<small>[ August 27, 2002, 12:36 AM: Message edited by: Tomuza ]</small>
\Shotimes faq page/
90 mtx 150+k
Thanks, Tomuza
