Is there a Tire Pressure Display in ForScan?
VernP
Atlanta, GA
I used FORSCAN a few years back to eliminate the double horn honk. But I think the answer is no.
Thanks,
Vern
Texas Marauder
Lone Star State
You can read the tire pressure in the BCM with a program like FORScan or FORScan Lite. Whether it's correct or not depends if you have the sensors in the correct position. The TPMS doesn't care about that since it only displays a low tire and doesn't indicate position. You cannot display tire pressure in the instrument cluster.
Majestic
About the only way you can (conveniently) monitor individual tire pressures is with a bluetooth adapter, cheap tablet and an app like torque pro.
VernP
Atlanta, GA
Hi thank you for responding so quickly. I did not think that I could display tire pressure in the instrument cluster. But I wanted to check to make sure. I read a few reviews about the after market tire pressure monitor using a bluetooth adapter, cheap tablet and an app like torque pro. I'll just keep it simple and do it manually.
V
markmoomnu
