avatar28
How much of a difference does the brake swap really make on a GEN 2? Most of the discussion seems to center around doing it on the Gen 1 SHOs. Is it worthwhile or just I just get a good set of pads and be done with it? If I'm understanding it correctly, all I need to do is go to the boneyard and pull a couple of caliper brackets off a 96-2000 Taurus or Sable of any trim level. I don't need the caliper. I also need rotors of the same ones, assuming they're in good shape. I replace the caliper brackets with the salvaged ones and do the brake job as normal (using the larger rotors). When I buy pads do I buy them for the newer model or still do I still get ones for the 95? Would upgrading the caliper as well as the bracket and rotor be of any benefit?
Beyond the 96+ Taurus upgrade, I can also get dual piston PBR calipers (and rotors?) from a Mustang GT but it's a bit more work? I did the latter swap on the 94 Cougar I used to drive and it made a very noticeable difference in stopping ability.
