norurb
SHO wannabe
I have an idea to rebuild/redesign the front end suspension on an SHO. I'd like to ditch the entire subframe, build new motor/tranny mounts and suspension points. Do you guys see any downsides or technical problems arising?
And I scrapped the aluminum ideaDo you guys see any downsides or technical problems arising?
That would be the University of Wisconsin's Aluminum Cow project. They replaced the steel engine subframe with one made of Aluminum, it was ~30 pounds lighter. Now, before you go jizzing yourself over this 30 pound savings, be aware that finite element analysis of their lightened subframe showed 3 times as much deflection as the steel subframe for a 1G (lateral) cornering load. U of W found this acceptable, and probably within their rights as a vehicle that got driven around to demonstrations and shows. For a track vehicle that's seeing ten or more 1G cornering events every lap - no way!Then again, there is at least one known example of an aluminum subframe used in an SHO...
....Now, before you go jizzing yourself over this 30 pound savings....
