shomesomesho
G-force addict
Is there any difference in ride/handling between the Intrax vs. Eibach springs? I read the Intrax lowers the car a little more than Eibachs but is there anything more to it?
I feel a bit of softness in the Eibachs when running down a Pennsylvania-smooth highway that isn't present with Intrax coils. It's a slight front to rear pitch, but noticable to me. My info comes from both first hand experience and SHOtimes.Sho-Driver said:I would not agree with the above. The Eibach's are not initially softer than stock. I have two SHO's that both have Eibach springs and they are no where near stock at any rate in the progression.
As far as which one is stiffer, that is a toss-up. Both myself and AutoSHO thought the Eibach's actually had a stiffer over-all feel to them.
The differing vertical distances between the coils in the Intrax springs indicates to me that they, in fact, are progressive. Perhaps the range of rate is less with the Intrax versus the EibachShoaz said:I'd thought that the Intrax were constant-rate springs, is that not correct?
Shoaz said:So for aftermarket constant-rate springs are the Moogs the only option?
