There is a bracket that bolts to the underside of the dash, one attached to the rear of the shifter, and one under the storage box. With the top of the console removed the lower section should line up with the pins that are sticking out of the dash bracket and the pin on the storage box bracket. There are two screw that attache the front of the console to the dash bracket, two that attache it to the shifter bracket, and two that attach it to the storage box bracket. You can now pop the top of the console on and put the screw in the bottom of the cup holder.
