intake question
93-G-SHO
Oxford, Michigan
hey i just took apart my intake today was wondering if anyone has a diagram to put it back together i have it all organized in i can put it back together but i would like a diagram of it just to make sure i get it right thanks
SHOGUN88
1994 MTX
Langley, BC Canada
I checked my ford service manual and didnt see one. But you really dont need one its pretty strait forward just take your time. If your not sure about something just ask.
sholover719
central va
its really not that hard to but back on, or take off for that matter i took mine intake off when it was pitch black dark outside with only a flash light and 2 hands at 12:30 am. and put it back on a week later after i got my spark plugs wires and valve cover gaskets it only took me about 45 min to put back on... there are i want to say 2 antifreeze lines and 2 vac lines the 1 antifreeze lines go to the throttle body and 1 of the vac lines to the throttle body also.. the other vac line is on the passenger side for the secondaries.. for the front intake runner.. hope this helps i should have taken pics of it ill be taken my intake back off here very soon cuz for some reason its still smoking from the pasenger side fireday and out the passenger side wheel weld. ill try to take pics if i can get my cam workin but i hope this helps alittle bit. so just remember it might look hard and diffacult but its really not.
93-G-SHO
Oxford, Michigan
thanks ya my buddy found out about the antifreeze to the throttle body the hard way pulled it off and sprayed him but ya im probly puting it together friday when i get my new intake gasket kit im thinking of powder coating my intake black do u guys think that would look good
sholover719
central va
ive seen a few pics with the intake powder coated if its done right it should look really good the person to ask about that is ken he just did he not to long ago. ive thought about like maken mine shine like crome by jet hot. this is the website. http://www.jet-hot.com/ i think they might be able to do somethen for ya they have a gloss black and a flat black.. what color is ur car? ive thought about maken mine match the color of my car which is green but idk.. if i dont make it match the color of the car i would like to either make my intake look like its crome plated w/o actully crome plating it. or just make it a color that would look good with the green ive thought about doing the valve covers too cuz if you do the intake the valve covers wouldnt really look right what they are stock. just my thought on the powder coting.
93-G-SHO
Oxford, Michigan
ya my car is completely stock for now its a 93 green ya im still thinking about powder coat but not for sure yet but i know a guy out here that does good work but if you chrome out your intake post some pics that sounds like it might look pretty good
sholover719
central va
i honestly have no idea when i would do it cuz money is really tight right now plus i need to get the body fixed cuz i got hit by a deer about a week and a half ago.. should be fixed soon once i save up the money i might dopla color it crome with a clear cost over it hope it will look good.
Kens1992mtxSHO
The Commonwealth
Putting the intake back together is a snap. If you've pulled it all apart just take your time putting it back together. You'll have to loosen the couplers when you go to install the intake again to make sure it sits flush to the engine. Once you've got the intake bolts tightened up you'll tighten the couplers. Remember to re-install all the hoses and the butterfly actuator on the back of the intake. Check for vacuum leaks.
