venomizd93
My first question is what is the black(size of 1/2 coke can)canister that two vaccuum lines run to on the back of the intake manifold. An is there only one way the vaccuum lines should be hooked up to it??? If so which way.
Second is what are the symptoms ofa bad DIS module???? I think mine might be going bad.....at sporadic time the car seems to be missing on acceleration(no pwer at all) and then kicks in normaly. New fuel pump(190lph) as of yesterday and the TPS seems to be working fine.
Got all 111 codes for KOEO and I can't seem to figure oout what the heel the KOER codes are telling me....they came out as 11652852XX2 or something like that and it repeated itself.
But none of those are in the chart headbang
