Instrament cluster
wolflord80
Maine/West virginia
I have a 93 atx and was wondering if it would be possible to put in a digital cluster and if so how to go about it if anyone has tried this or has any ideas please let me know
jelloslug
Digital
Greenville, SC
Yes, you can put the digital cluster in. Its not very complex, you just need to get all the parts from a parts car to make it work properly.
megaplay
Cincinnati OH
I have seen it done. Well sort of. Person took a sable with digital dash and dropped a sho engine and of course everything that goes with it like the computer it. I contacted him and he said the only hard part was tracing out each wire and wireing it correctly to the dash. There might be and easier way I have thought about it before but never got to far into it.
jelloslug
Digital
Greenville, SC
I have had my digital dash in since Christmas. With good wiring diagrams its easy. Its like putting in an aftermarket car stereo except I think there were around 60 wires to hook up. Most of the wires are right there at the cluster already, I had to run 3 new wires from the engine area, 1 to the EATC head, 1 to a constant live source, and a few others here and there to make everything work properly. You have to change the coolant sensor to get the gague to work correctly and the chime module if you want the beeps from the cluster to work. Everything on the cluster works but the miles per gallon is off by exactly 1/3 but the miles to empty works correctly :confused: . If you want to do the swap I cannot stress enough to have access to the car the dash came from, you will need more than the cluster itself, and parts for the digital dash are hard to come by.
TaurusGuy
Omaha, Nebraska
Any chance you could do a write up on exactly what had to be done for me? I really want to do it, but don't know all the info...
