LJRuddy
Pop lock n drop
Well, I decided that it was time to install the JL 10w3 that I have had sitting in my house for over a year now. I picked it up for 50 bucks last year and got a ported sub box and a cheap amp for free with it. I also had a new in box line out converter.
After reading the directions, I figured that I needed to find the RR and LR speaker signal wires that go into the passenger side amp (JBL premo sound system in my 95) and cross them with the wires indicated on the line out converter. After finding the 4 wires for the 2 rear speakers, i attached them to the converter and sealed the connections with some solder and electrical tape. According to the converter's manual, all I needed to do was find the remote wire from the JBL system and attach it to the converter. I found this wire to be a solid blue wire. I attached that to the converter's remote wire in the same manner. From the diagrams on the manual, I found that the only wires i needed to hook up on the output side of the converter was the 2 RCA wires labeled "Rear" as well as the remote wire and attach these to the corresponding spots on my amp. I ran the power wire from the battery to the trunk and hooked everything up but nothing worked.
According to my volts meter, i am getting 11.79 volts at the terminal on my amp. I also plugged in my JL 10w7 into the stock sub amp in the car and it works so I know my sub is good. I am guessing my amp is bad but I am not certain as it worked the last time it was in use.
My question is this... Can anyone tell me what colors the 4 wires for the rear speakers are in a 1995 SHO with the JBL premium sound system? It was my understanding that I only needed to attach the 4 rear speaker wires to my line out converter and use the converters RCA wires labeled "Rear" to hook up to my amp. Is this correct?
Thanks a million!
Thanks a million!
