JRA2000TL
The Complainer
I start DDing the 89 a week and more crap pops up, big surprise there.
So I have an inlet air solenoid, code 81. I checked it--yep it's there, yep, the electrical connector is plugged in, and yep, the vacuum lines are connected. I know what it is---it's the little thing next to the round canister on the back of the intake. It clips on there, has 2 vacuum lines that run from it to the intake, and has 1 electrical connector.
Bad PCM possibly? It's an 89 CA emissions car, so a PCM might be hard to find. The car runs and drives fine, although the other day when I got on the gas hard, the car bucked violently, tach went to 0, and it just shut off. I pulled over, made sure the DIS was plugged in (one end is cracked and the connector sometimes is loose). I checked the battery connections and re-started the car. I drove probably another 60 miles around town with it fine. It hasn't done it since.
I unplugged the connector, cleaned it with electrical cleaner; cleaned my TPS also. I disconnected the battery for 10 min, re-connected, and drove the car. After about 2 miles, the CEL comes back on.
I also had some other random codes: 13, 33, 41, 91.
13 could be a bad IAC. I think I have a spare I can swap to check.
33 is EGR crap (CA emissions car; it's all connected properly)
41 is a fuel lean code (it does run rich, might replace O2 sensors anyway)
91 is also a fuel lean code
Any ideas on this 81 code? I did a search and it has been explained well what it does but not really how to fix it. I read that it could be a PCM issue.
