93rev2sev
I would like to build an automatic fuel cutoff switch that can turn the fuel pump on from the drivers seat for theft prevention.
It would disable the fuel pump every time you turn the car off and would require you to press a button or flip a switch to turn it back on when you wanted to start the car...with the key in the "on" position.
I could just use a regular switch (that would be really easy), but I don't want to have to remember to turn the pump off when I get out of the car.
I have a feeling there is a relay that will do just what I'm thinking about, but I don't know relays very well.
I know this has been done before and I'll admit that I have not searched. The only information I need is a model number of a relay that will break when the car is turned off and needs to be reset under power.
