Im Starting <> HERE <>
Gen2Gen3WhatNxt
Toledo, Ohio
Please Correct me if at any point I am going a$$backwards on this deal.
<>SHOrt TERM GOALS <> . . 1- Large ATX cooler 2- ALL Fluids and Filters replaced/flushed 3- Exaust, possibly Delta flowmasters, what else? for the sound ofcourse. and for a DIY'er I would like to get that AirBox resenator or whatnot out of the way. <> LONG TERM GOALS <> 1- Summer time 17's that really look good. 2- possibly The chip if I get board #3 O yes a RAGE body kit would be great wouldent it.. ya,,,and then i wake up thinking i have to paint the new body kit.
Steve Dionne
Methuen, Ma.
How about some suspension stuff; front strut tower brace, front and rear sway bars, endlinks and bushings, sub-frame connectors are all great mods for the $.
Mr. SHO
Philadelphia
Sounds like the way to go, with one caveat--the SHO is MUCH more responsive to suspension mods than it is to performance mods. The stuff you have listed in the short-term is absolutely right. Don't forget to flush the brake fluid--mine was practically BLACK near the rear calipers, and I was relieved to replace it with fresh DOT 3/4.
I would put bigger sway bars (24front/25rear or 24front/26rear or stock front/23mm rear) in the "mid-term" category. It makes a DELIGHTFUL difference in handling. :)
Good brake pads make a difference too. The stock Ford pads are quite good, but many used SHOs have some crappy store-brand aftermarket pads on there as replacements.
Gen2Gen3WhatNxt
Toledo, Ohio
I will be looking into suspension mods (sway bars for sure) but everything elses on suspensions department will be wating untill it is actually due to be replaced. Got to save money somewhere. As she is right now, has a new rack and pinion and tie rods. She sits nicely, so thats not high on the list of priority.
But what about these ATX, im already afraid, i heard today a rather loud engaging CLICK when going form Reverse to Park. Every other shift is smooth and strong, except that reverse to park. Is this an indicator of any thing i should look into? Either way im sure of the Aux Tranny cooler as being the first thing I want done.
Gen2Gen3WhatNxt
Toledo, Ohio
Im looking into the ATX cooler. So is B&M the way to go or what? I ordered a summetracing catalog, Is the tranny cooler (B&M) going to be listed in there? thanks, to people that actually respond.
Gen2Gen3WhatNxt
Toledo, Ohio
I think the idea of the temp controll of a B&M sounds good, Ohio can get really cold in the winter time. From what i understand when i install this transmission oil cooler, that i will continue to also use the previous oil cooler in my stock radiator, is that right? :huh:
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
You can if you want to. Just run the lines from the stock cooler to the aux cooler then back to the tranny again.
99V8SHO
GasOilAndTires
why cant i post pictures of my cars? it says that i may not. :huh:
You trying to put them in your sig? Are you sure you are using the
yamahaSHO
E85 whore
Arkansas
They have to be hosted on a server....
Then you use the image tag...
... with the address of the pic inbetween the two image tags.
Gen2Gen3WhatNxt
Toledo, Ohio
Ok ic, well i dont have a server so i guess no one will see the new pics
