IAB ???
Splitz
Burlington, Ontario, Canada
I have a 94 SHO slush-O-matic, I was wondering the best place to get a replacement for my IAB, it doens't seem to be the type that can be cleaned. Also how much do they cost???
I really hope i don't have to go to the stealership for it =(
thanx in advance.
projectSHO89
SHOless In St L
Around $50-55 bucks at any parts store.
$54.95 at my neigherhood AZ last month.
Here's a shortcut for installing it - Use a hacksaw on the lower mounting ****** to create a slot opening instead of a round hole opening. This will allow you to tighten the lower mounting screw almost to the needed setting, then just slide the IAB onto it and insert the upper mounting screw. Trying to insert the lower screw the conventional way can lead to a screw dropped down into the maze of plumbing below it. Tighten both screws to spec.
Steve
David Carpenter
