i want to lower my car!!!!
Trey Randol
minnesota
i want to lower my car 2 inches but cant find any springs to do it please help eibachs are not low enough for me intrax is getting close id like to have 2 inches.
thanx
PROPHET
Well-Known Member
Tonytown, Texas.
The Intrax will give you the lowest stance.
Or you can maybe find some of the old Shoshop springs for even lower but that want be easy.
Or you can cut the intrax or eibachs.
SHOZRJUSTBETTER
South Shore MA
I believe the Eibachs are progressive rate, which is good for performance and non-performance driving, on the other hand the intrax are lower, but the performace is moderate, not outstanding imho... I have an intrax and koni setup... one more thing, my opinion might be wrong due to poor installation.
good luck
andrew g.
The lower you go, the more difficult it will be to keep the suspension within the alignment specifications. Be forewarned. The drop from the Eibach springs on my car required adjustments at all four corners that were beyond the limitations of the original suspension adjustment capabilities. Too low will also be detrimental to handling and certainly the ride. Or are you even concerned about that?
