I guess compressor is drive line.. AC problems
TwiceSHOwn
Atlanta, Ga
Anyone have an estimate on replacing a bad compressor on a MTX with a R134 model (meaning changing it to r134 from r12)? I am guessing around 1000 but hard receipts of those that have been there would be great.
Im willing to bet the labor is going to be a bit#$.
93 Silver ATX 58K
Eibach + Tokikos
Rear STB
Y-Pipe
SHO Shop catback
TCE SHO stopper brakes
Under warranty till 94K and 2004!
Mods in a box...
LPM
80MM MAF
3 guage pod + guages
24/26 Sway Bars
Cold Air Induction
ThrillSHO
Wake Forest, NC, USA
Dude,
Been there. You can't get a warrantee on the new compressor unless you replace the dryer/accumulator and orifice tube also.
Conventional wisdom says stay with R12, R134 operates at a higher pressure and does not absorb as much heat. If your system has a weak spot (o-rings, seals, connectors, ect) R134 will find it and even if it doesn't it won't be as cold as R12.
I had the whole thing done and the R12 recovered and recharged for just under $1k. Go to 4 Brothers AC in Raleigh. They're the best.
ThrillSHO Racing
93 ATX SHO
UDPs, LPM, 80mm MAF, K&N w/CAI Snorkle, 8mm Taylor wires, Koni Struts, High Rate Linear Springs, Camber plates, Adjustable rear control arms, Touque box brace, Poly bushings, 24mm front SB, 26mm rear SB, Alum SFB, Full-length SFCs, Front & Rear STBs, SS Y-pipe, Borla Cat-back, TransGo Shift Kit, Relocated battery, Five point harness, Five 2" gauges below the CD player, 225/45s on 16x7s
Very Low Very Fast
Coming soon: Coil-overs, shaved SFBs and smaller front swaybar!
Even Lower, Even Faster
