hubs
shooff-usa
Hi there!
indiana
Will my origional '91 hubs(with new bearings of course)work in the '95 knuckles I just got?The stuff on the knuckles is a little rough so I figured I'd use my hubs,which are in good shape, I want new bearings anyway, so if it's possible,that's what I'd like to do.Is the caliper mounting the only difference between genI and '94-'95?
Todd TCE
Tempe, AZ
Using old hubs and bearings at this point is plain foolish. Getting them out of the old knuckles without damage is more than a bit tricky. (I've done more than a few- maybe 250?) If it's going together put in the new bearings and a fresh hub. If you can't afford this level of preventative maintenance maybe you should reconsider the entire project.
shooff-usa
Hi there!
indiana
As my post says,I will be using new bearings.Since the jy's here all take the wheels off,ALL hubs are very rusty,mine are not.I feel replacing the bearings,and going with a larger brake set up is more advantagous and safe than A)Keeping the factory set up just to forgo changing bearings,which,at 104k,probably need to be changed anyway or B)using the jy knuckles as-is,with rusted bearings and all.
