So I looked around for some more information on Ford pressure sensors...
Found this site:
FordFuelInjection.com
Their spec/function page on the
Barometric Pressure Sensor. (BAP)
The sensor frequency increases as vacuum increases.
Unfortunately, that's wrong.
I set up a little garage experiment to power a couple of BAP sensors at 5V and check their wave-shape and output frequency with an O-scope and frequency counter. (Yeah, I have this stuff in the garage, I have even better stuff in my real electronics workshop.)
Sensor at Atmosphere = 137.0 Hz.
Just for grins, I looked at the sensor at 20" Hg vacuum.
Sensor at 20" Hg vacuum = 87.3 Hz.
And at 5psi.
Sensor at 5psi = 167.7 Hz.
Fordfuelinjection.com says, "The sensor frequency increases as vacuum increases." Mind you, just this statement is wrong, the graph of pressure -vs- frequency is correct, and the tabular data is also correct
except for the entry at 9000 feet/21.0"Hg/72kPa, this should be 134 Hz, not 138Hz.
So, my data on two BAP sensors says that ...the sensor frequency output
increases as pressure increases.
Pressure Frequency
-20" Hg = 87.3 Hz
-15" Hg = 99.9 Hz
-10" Hg = 112.4 Hz
-5" Hg = 125.5 Hz
Atm* = 137.0 Hz
One sensor was a SHO spare, the other I robbed from my SVO. At 5 pressures, they both agreed within 1 Hz.
* Keep in mind that I live at about 6500 feet altitude, and there's a winter storm roaring in here this afternoon, so between those two, my normal barometric pressure is quite a bit lower than sea level pressure of 29.92" Hg. Up here, I'm at about 22" Hg. So for me, -20" Hg on my vacuum gauge is really 22"-20", or 2" Hg absolute, or about 87Hz from a Ford sensor.
Now, let's have a look at FordFuelInjection.com's
Manifold Absolute pressure Sensor page.
Same (wrong) statement:
As with the BAP sensor page, the pressure -vs- frequency graph is right, but the tabular data is wrong: The frequency column is inverted, it should read 80Hz at the top for 0" Hg, and 159Hz at the bottom for the 30" Hg entry. Just invert the whole column of numbers so it reads 80, 88, 95, 97 etc., top to bottom.
Now let's go back up a few paragraphs to my 2" Hg absolute that I got by applying -20" Hg to my sensor in a 22" Hg atmospheric ambient, and got 87 Hz. Look at the BAP table now that you've re-ordered the frequency column, 2" Hg would be between the 0 and 3 Hg rows, but closer to 3, and somewhere between 80 and 88 Hz, but closer to 88, right?
Apologies for the long post, but I just hate it when I go out on The Internets and find errors. I sent a message to RJM Injection Tech, hopefully they will correct this.
