How to put fluid in an ATX?
underdog1924
Haverhill, MA
I need to add some fluid into my ATX, what is the easiest way? I think I read once to put a tube over the dipstick and pour it that way. Also I read on another post that it's good to fill it to about 5/8" over the "fill" line on the dipstick. Is this ok and preferred to do? Thanks
SHOtimer
#2910
Santa Clarita, Ca
Well you have to fill it up through the dipstick tube. The easiest way I have done it is to put a funnel in the tube, then get a water bottle and cut off the bottom then hold that above the funnel. So you have sort of a double funnel effect so you don't spill. I have always kept mine at the full mark, never heard about overfilling. I just know it is a good way to blow trannys seals by overfilling it. Make sure the tranny is hot and it is idling in park to get an accurate reading.
Doug
shocrates
will never know
NJ
I overfill my trans 1/8"-1/4" and haven't had any problems. I've read the most it can safely be overfilled is 1/4". 5/8" seems like a lot to me. Do you remember what post recommended 5/8"?
SHODWN
Mother Threasa
Spencer,Ma usa
Overfilling has been around a long time, most will add 3/4 of a qt extra to it. It helps in cornering so no air gets into the system.
Also if you have a Transgo it is required..
