Transmitter Programming
To program (or re-program) transmitter(s) into the electronic door lock control processor, perform the following steps:
1. Turn ignition switch to RUN or ACC position and momentarily short the two terminals of the program connector (J4) (a two-pin connector taped to the wire assembly is accessed by removing the left hand luggage trim panel). All doors should lock then unlock. Remove shorting pin.
2. Press any button on transmitters. All doors should lock then unlock, to verify that transmitters have been programmed.
NOTE:
If door locks do not respond, press button again (up to three times maximum with the same transmitter).
3. Turn ignition switch OFF. All doors should lock then unlock.
4. Check operation.
NOTE:
The electronic door lock control processor erases all previous transmitters from memory when the transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four transmitters in memory.
