How to change the blower control module?
Mike Compton
Ashland, NE
I know that it is placed behind the glove box somewhere...other than that, I know nothing. Is there a how to or tech article somewhere on how to do that? I am tired of being cold on my way to work in the morning. I have 2nd car that I will take the BCM from, so I just need some instruction on HOW. Thanks.
Goulash
Urbana, OH
It's more under the glove box than behind it. There's a panel below the box that is held on by these 2 semi-bizarre clip things: I just twisted them off with gloves. You'll see the module: if you have any doubt as to which piece it is, it's the one with the sticker on it that says "BLOWER CONTROL MODULE."
Replacement is easy...just remove the two 8mm bolts, unplug the four-wire harness (which might run up behind the glove box), and undo the black hose. Installation is the reverse of removal!
Good luck!
- Justin
shofun93
Rootstown, Ohio
only took me about 20 min. I needed a 8mm socket and an extention for my 1/4" ratchet to reach the screws. Could be done with a socket driver.
