How hard is it to change clutch
SHO IT
ST. LOUIS, MO
just wondering how hard it is to change the cluth. im pretty sure mine is pretty worn and i would like to put in a better clutch. what clutch would you guys recomend
AREA 91
PA SHO SHOP
Area 91
Get the clutch video from Josh T. at shonutperformance.com finger He is hail
TheNoachSHO
Windsor Locks, CT
Depending on your confidence and ability's it could be very diffcult to not more then an afternoon ball buster.
I just did my first one and it wasent too bad. About 12 hrs to do but that was without taking shortcuts, completely removing the subframe and tranny. We used Josh's video and instructions as a guidline and our own common sense for the rest. the worst part is putting the tranny back in the car.
Good luck.
TheNoachSHO
Windsor Locks, CT
I'm sure that it can but i'd be willing to be it's much more diffcult. With doing it through the bottom you don't have to unbolt all the steering pump, ac lines, electrical connectors and just about everything up top of the motor.
Just build a cheap home depot support, go and get four 6 ton jackstands and a good high lift SUV jack and you'll be all set.
