How do I remove the 24V emblems?
Blast7
Rochester, NY
I am looking to remove the 24V emblems from my SHO without damaging them and didn't know how they were attached. Can someone explain the best way to remove them?
SHOGIRL1994
ExFSHOCmanager
Jacksonville, FL
They are just attached with a glop of gray adhesive stuff. If you don't have a heat gun you can use a hair dryer. Use that to heat up the adhesive and gently peel it away. If it doesn't want to come off easily, you can use a plastic knife to gently pry it off. Just be careful not to take any of your clearcoat with you.
Cocoa,Florida
if there the orignal its a glop of gray goo,if its the newer style like they sell now its some double sided sticky tape kinda like weather stripping...but thinner
mosho93
Well-Known Member
Wausau, WI
Yep, I used a heat gun for mine..and then went to wal-mart and picked up some magnet strips and made great magnets!!:)
Redline
Fire It Up
Sandpoint
Sweet, I should do that with mine. What about the ford and taurus badges on the back of the car? They attached the same way?
Venom SHO s7
Washington
nope, wish it was though
No, the Ford and Taurus badges on the trunk lid have both the adhesive and have two small pins, so if you take them off, there will be two small holes where they used to be. :frown:
