There is an old engineer's addage about assuming. It says that do you know what happens when you assume? You make an ASS out of U and ME. Put the letters together.
You can't solve a problem by guessing what it is. You really need to locate the source of the oil leak to be sure you are really fixing the problem. To install either the oil level sender or the oil pressure sensor, you will have to jack up the car and crawl underneath.
The oil level sender is located just a few inches above and to the passenger side of the oil pan drain plug. It is just below the normal level of the oil in the oil pan. The leak does not change rate between engine running and engine stopped conditions. The drip from this sender will show up on the passenger side of the oil pan drain plug.
The oil pressure sensor is located below the number 3 cylinder (driver side, rear) on the block. This sensor leaks MUCH more when the engine is running and will develop a large puddle very quickly under the driver side of the engine block, to the driver side of the oil pan drain plug.
Scott
1991, 253K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
