oboytroyman - please stop starting 8 different threads for each problem you encounter with your car. Also, spend a little more time describing the issue at hand. If your car is bucking and hesitating at high RPM, it might "feel like it's running out of fuel" but that is a poor description of the symptom. Saying that "the car loses power above 5500rpm at anything over 1/2 throttle" or "the engine bucks and jolts when it's floored over 5500 rpm" means a lot more.
Also (me taking pity on you), check your spark plug wells to see if they have oil in them, and check the condition of your spark plugs and wires. If your spark plugs / wires are severely worn out or there is oil in the plug wells, your car can buck and jolt and feel like it's missing fuel at higher RPMs. PLEASE search for how to do these things, they have been covered 100x on the forum.
