How can the faulty speedo be fixed?
V6&V8SHO
wauconda, IL
In the 98 SHO's the speedo drops to 0mph after 110mph. This is do to distrotion of the info from the a.b.s. sensor. Is there a fix? My dad still has warrenty on his 98 SHO and would like it fixed. Does the 96 97 or 99 SHO does this? If not then there has to be a fix.
elcapitan87
Clarkston, MI USA
My 97 speedo was rock solid to 140 or so. Don't know if it would help to swap a computer from an earlier car. The '99s had a different gauge cluster anyway, so I don't know if they'd be any help or not.
Ryan Dudek
mholhut
MA
No known fix.... other than driving below 110. Invest in a radar gun or an aftermarket HUD maybe???
LASTSHO
MinneSHOta
Or a GPS....I get a readout all the time.
Ford won't fix it because they say theres now way to test it and we don't need to be doing those speeds anyway :rolleyes: burn_out
V6&V8SHO
wauconda, IL
Its the pupose of it. They must have tested the 98 sho to its limits and they must have known of the problem.
V6&V8SHO
wauconda, IL
There must be a way of fixing it if a 96 97 or 99 SHO doesnt do it. It doesnt make sense why the 98 sho does. Possibly a design flaw dating back to the assembly line?
mholhut
MA
It doesn't happen with every '98 SHO or any particular SHO for that matter. If this bothers you, wait until something more troubling happens to the car.... tick tock tick tock tick tock...
From that lovely resource v8sho.com, which I take, no one cares to read anymore....
Speedometer Failure at Speed
Thanks to Chris Swinford
An excerpt from an E-mil to Bill Moore and Doug Lewis:
First I want to thank you for the best site on the Gen III SHO. I recently purchased a 98 SHO new and I am loving it. I have had detailed discussions with Doug Lewis regarding what I can do to the car to make it quicker/faster...but first I must wait for money.
I am writing to inform you and all readers of your site about a acknowledged problem with the 98 SHO and the speedometer at higher speeds.
at speeds in excess of 105 mph, the speedometer in my car (and others according to Doug Lewis at FPS automotive in atlanta and Ford SVT Tech support line) drops like a rock to zero. I have taken the car into my local Ford dealership, and because of the speed, no technician is willing to "verify" the problem. The dealership did call Ford SVT tech support and got the following explanation of the problem.
according to Ford, the problem exists with the communication from or between the a.B.S., G.E.M. (General Electronics Module ?) and Speed Control. The way it has been explained to me, that unlike other Taurus, the SHO gets its input for the speedometer from the a.B.S. sensors. On the regular Taurus, vehicle speed is read from the transmission. The signal from the
a.B.S. is converted into a corresponding frequency to be fed to the speedometer. at the speed of 105+ mph, the frequency gets distorted and the speedometer can't figure out what's going on and essentially turns off. Unfortunately, for those who have a silly streak a mile wide or who live in Montana, the odometer still works.
I have been told (from SVT through my local Ford Customer Relations Manager) that an individual in Canada who races the SHO has had the same problem and fixed it by disconnecting the G.E.M and Speed Control modules. This is great for those who don't need headlights, stereo, wipers, etc... but for all others, this is not a workable solution.
So far, the number of complaints to Ford have not been enough to justify a recall. I am asking all owners of the 98 SHO, the last model year, to help out with this cause. This is NOT an issue of the speedometer turning off for the sake of safety. This IS an issue regarding faulty manufacturing/engineering and the lack of complaints to justify a recall. If you have a car that exhibits the dead speedometer above 105 mph, you must do the following.
1) Tell you local Ford Dealership to file an E.D.S.R (Electronic Dealer Service Report) to Ford regarding this problem. They may protest and ask you to call the below number, but do not cave and make them file the report.
2) Call the Ford Customer Service Number and report the problem yourself @ (800) 392-FORD.
I would be curious to hear how many have this problem and where they have gotten with Ford.
Good Luck & Thank you in advance!
Chris Swinford / [email protected]
Elmhurst, IL
Mac98SHO
Pine Island, MN
Well maybe some people should take a steps to make better webpage (informative) that people will care about more. thumbs_u
hosbaldosho
