SHOracer14
Me-0 Diffs-6
2 weeks ago I curbed the plus pretty darn good. I ruined a rim, bent an inner tie rod and also bent the subframe. Yesterday the car finally got put back together with another subframe, new steering rack, new lower control arms, new outer tie rods, and new endlinks. What wasn't replaced still looked good. Now I went and got it aligned this morning. The guy says I have a bad motor mount so it will torque steer a bit. I thought eh, these cars have a little torque steer anyways so thats probably what he felt when he drove it. I drive it and want to park it right away. The torque steer is unbelievable. In any gear at any rpm and any throttle input (when off the gas the alignment is perfect) the car just pushes horribly left. This doesn't make sense to me as the car never did it before and all the mounts were in the same condition (they still looked ok to me). The only thing different that I did was the rubber on the tranny mount started to seperate so I jb welded it as a quick fix to get the car back on the road for now. I also have a different tire on the front passenger side (215 60 as compared the rest being 225 55) until I can find another white rim. I will rotate the tires and see what happens but I just can't believe that that small size difference would cause this much of a driveability problem. Also, will bad motor mounts really cause horrible torque steer? I'm just looking for answers on why this is happening because everything is put back together correctly (yes the subframe is aligned) I put all this money on new parts into it and it drives worse than it ever did. I'm just frustrated... please help.
