Horn?
Dhark
Ever since I go my SHO the horn was pathetic, clown car esque. Well now it isn't working at all. I ordered a new horn but have no idea where it is. I searched everywhere. Anyone know how to get to it?
bpd1151
Lurking Around
SHOcago 'Burbs
Located on the driver's side, temporarily hung on the assembly line by a small metal hanger, and is then fastened to frame with one solitary bolt near final assembly.
You can access it by removing the under belly pans, and/or removing front bumper cover.
In this pic of my meth install from several years ago, the dual horns are seen in front of the Alky Controls meth pump.
Hope that's of some help.
Dhark
Thank you! Which way would you say is fastest and easiest
bpd1151
Lurking Around
SHOcago 'Burbs
Probably to just remove the plastic under belly/engine covers.
It might even be beneficial to remove the left front tire and the corresponding wheel well liner to provide you even more room.
Just to make life easier.
