horn+cruise control dont work
89SHONOFF
Columbus,Ohio
as title states,i heard on sho there is some harness that melts is that true?what is the problem most likely?thanks
1989 SHO Lt.Titanium
K&N Filter
Msw Wheels
Hopefully More Soon!
1968 Buick Skylark W/455 Stage 1
70 Ford Torinow/302 and 60k miles.
1990 Honda CRX SI"Riceburner"
jthomas68
Area 51
I just puller my steering wheel off about 5 minutes ago.There is one clip for the air bag,and another for the horn/cruise.I really don`t see where they could melt,but i`d try pulling the air bag off and check the wires from there.It could have rubbed and split a wire,if not,you`re going to get into the column.
Jeremy Thomas
Juiced 91+
SHO Pic Of The Week:
T
ThatSHOkid
Guest
same problem here. as soon as you find otu post hyere as i need soem help also.
1993 White/Tan SHO MTX 98k Miles
[*] Performance: Sho Shop Y Pipe * Coneless & Boxless * 80mm MAF * S & B Motorsports Concial Filter * Ted B Performance Chip
[*] Appearance: Colgan Custom Bra * "SHO" Windshield Banner * Blacked Out "SHO" Lettering * Ventshade Sunroof Wind Deflector & Vent Guards * GTS Headlight Blackouts
[*] Audio: Sony 10 Disc Changer
[*] Lighting: Eagle Super White Headlights * American Products Company Super White Reverse & License Plate Lights * Blazertech Foglights
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Sway Bars, Front Strut Tower Braces, & A Sig Pic!
[*] The Driver: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] The AIM Screename: KingPin641 (a NESHOC member)
"Drive it like you stole it!"
J
Jeremy Hohn
Guest
I don't know about the cruise control, but the horn is an easy fix right back of your driver's side fog lamp and you can replace it with one from your local parts store in about 10 minutes. Good luck.
Jeremy
1993 atx 122k miles
-PIAA headlamp bulbs (thanks Fratperformance)
-fish tanks installed
-fog lamp mod w/ blazer fog lamps
-6" 5% tint border on windshield
-black body filled lettering
-wclewis "powered by yamaha" badges
-Sho Shop Cold Air Induction Kit
-Lund blackouts front and back
-cincysho colgan half bra with "SHO" lettering
-KVR chrome cadmium plated rotors with carbon fiber pads
-Sho Shop cat back system with magnaflow chrome tips
-Performance Plus y-pipe
-TX personalized plates "SHO FUN"
-Shoshop underdrive pulleys
-Shoshop 80mm MAF
-60k completed by Sdpatt
-Redline atx tranny fluid and water wetter
-Ted Breaux LPM
-D4U1 computer upgrade
-Rebuilt 94/95 AXOD tranny with TRANS-GO shift kit
Nebraska SHO
Lincoln, NE USA
I had this very same probelm. I mean exactly. At the bottom of the steering column under the dash the wires for the horn and cruise buttons on the Steering Wheel come out and go into a clear plastic connector (on my '92) (trace the wires from the buttons if you cant tell which ones). The wires had been cut right where they go into the connector. We took the connector apart and there are 2 thin (very thin) metal fingers that the conetor uses for contact points. These are what the wires are supposed to tie to. We got the metal fingers out and soldered the wires back on and used some shink tubing. You can't put a blob of suff on of the metal fingers will not fit back into the connector. We re-assembled and wallah everything worked....
Hope this helps
T
ThatSHOkid
Guest
what does the realy look like? and also do all tauruses have them?
S
SHOGIRL94
Guest
Check your Cruise Control Modulator. Its a little black box that sits / plugs in right behind your TB. Mine basically self-destructed by shorting out somehow and melting. If this is the case, you can probably get the part for around $50. I've had several offers in this range. Good luck!
TM
shobanner.txt
1994 Silver Frost ATX
Removed Outer Intake Box / Cone
Cobra 18WXST
Blue Dash Lighting
Cute Blue Valve Stem Caps
SHO Windshield Banner
NHRA Seat Belt Pads
Bosch Plats (no problems!)
Shoman594
Moderator
Lockport, IL
myshonuff
orlando,florida,usa
my brother has the same problem with the cruise control module.getting the module is not the problem its getting the replacement plug to the module.i went to the ford dealer and he could not locate it and told me its looks like i would have to buy the whole harness.any help ?
myshonuff
orlando,florida,usa
oh and by the way when the cruise module went so did the horn and cigar lighter seems like the way its wired if the module goe so do these.
munkee
Too busy...
Missoula, MT
Myshonuff, sometimes you can cut the plugs you need off of harnesses at a salvage yard and save a heck of a lot of money. They usually won't let you cut them off unless the harness is shot already though so locating one might be difficult.
"It's not just the speed, it's how well you handle it."
myshonuff
orlando,florida,usa
i did try the junk yard for the harness since they told me they had a 93 sho but when i git there the first thing the owner told me was dont cut any wiring from the vehicle so i looked at it to see if at least it had the module and to my surprise i open the hood to find nothing inside at all and i mean nothing.i contacted ford dealer and was told ford no longer stock that plug for the cruise guess ill have to make due with the partly melted one.ps used sho any years are very scarce at junk yards.
T
ThatSHOkid
Guest
what does this harness look like? the harness controls cruise, horn, and lighter?because i may try a junkyard. also, do all tauruses have them?
