High Beams not working.....??
stangeater
Farm Boy
Okay, went and picked up my car yesterday!! The low beams work great, but when I switch them to high, they just go out. I did read some other posts about the multiswitch function, and possibly a fuse. I can check the fuse, but what is the multiswitch function? Thanks for any help.
Jeff
93rev2sev
Hockeytown
The turn signal stalk.
Remove the column shroud and use a t-15 to remove the 3 torxhead screws. Unplug the Multi-function Switch and remove it.
Dissassemble and fix, or simply replace it with a known good unit.
SHO_DOODmorrris
Owner & Fanatic
Alberta
I had a simaler problem but i had no lows! that was crappy. replaced multi disfunctional switch and i was laughing. BTW i have a Gen 2 multi switch as i bought the wrong one first. GL
-Mitch
93rev2sev
Hockeytown
Picked mine up off the ground under a 95 Windstar in the junk yard. It was $2.25 and has been great for $50,000 miles.
SHO_DOODmorrris
Owner & Fanatic
Alberta
Got mine form pick and pull off a regular 89 taurus. paid like 4 or 5 bucks and works like a charm, i also snipped off the cnnectors as mine had cracked and melted due to a short. anyhoo it works like new as i said. good luck.
-Mitch
