XLSuruaT
I have a 96 taurus lx. I figured since the engines and engine control setup are very similar it wouldn't hurt to ask you guys. Here's my post copied from duratecperformance:
Ever since ford put a rebuilt engine (rebuilt long block and swapped over EVERYTHING else from my old engine) in my car, I have felt a hesitation while crossing past the 4000 rpm mark. It feels like the car is going to shift, it doesn't, then accelerates as it should have in the first place, then either:
1) repeats the same hesitation at around 4700 rpm then accelerates like it should, then crisply shifting to 3rd
2) shifts crisply to 3rd.
The same can also happen in third, but it only hesitates once then shifts. I really cannot try to see if it is doing the second hesitation otherwise I am going well above the speed limit. This happens while giving the car approx. 3/4 throttle.
Ford put a rebuilt transmission about 6 months after the engine was replaced and this did not change the hesitation one bit, so I would be very surpised if the trans is bad. This is a 1996 ford taurus 3.0l duratec 24v, engine repalced at 60k, trans at 65k, currently at 69k. Any ideas?
<small>[ November 09, 2003, 02:00 AM: Message edited by: XL-SuruaT ]</small>
