keny_kimmel
ETSN Kimmel(SS)
I've read a lot of posts and what not about the SHO lighting situation. It sucks. I want to upgrade my fog lights to some good quality HID lights. Not just the bulb, the whole assembly. Well, in conjunction with some good HID bulbs. What I want to know is, If I upgrade the lights can put in a...**** I don't know...100w bulb? Or do I need to uprgrade the wiring harness? From what I've read anything over 85w will melt/burn the harness and the housing. In my part of the state the brightness issue doesnt apply as long as your not having the lights aimed up at other drivers. So over all, what has to be done to successfully replace the stock fog lights with some good quality HID-turn-night-into-day lights?
Also...How can you wire the fog lights to useable when just the parking lamps are turned on? I see that everywhere and I want it. And one last thing, How would you wire the fog lights to allow you to turn them on when the high beams are on? I've got tons of roads around here where there isn't one street lamp on em. So I want this car BRIGHT.
