HELP! Sway bar end link NUT!
wood_e
The dude
Ames, IA
Well as I am trying to finish up my 96 brake upgrade I noticed that one of my sway bar end links (that the ford dealer serviced a few months ago) was completley off the strut (where it connects). The bottom is well secured, but the top was off. I can't find the bolt anywhere.
Where can I get a bolt that fits??
<small>[ January 17, 2004, 06:24 PM: Message edited by: wood_e ]</small>
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
somebody is bound to have one...
it seems that everyone but me has a parts car these days :D
If you dont get much response here, try posting a want-to-buy ad in the classifieds thumb
wood_e
The dude
Ames, IA
Well as ridiculous as this sounds i need this today... I was wondering if anybody knew where I could get one quickly. Maybe i could give the ford dealer a call?
heh, if I had a parts car I'd use it wink
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
well, how about this:
pull the bolt off of the other side, and take it with you to find a new bolt from a hardware store?
My SHO is in a friends garage all torn apart right now, and I have the endlinks off... but Im 12 miles away frown
wood_e
The dude
Ames, IA
OMG I am a effing retard! A NUT..... and yeah my local ford dealer had one.
A better question...
I have it on there pretty tight. Are there any washers that space setween the nut and the end link (on the strut)
EDIT: editited the title for clarity/ me being dumb
<small>[ January 17, 2004, 06:25 PM: Message edited by: wood_e ]</small>
wood_e
The dude
Ames, IA
dang, I thought that would be the answer. I can't under my own power tighten down my end link and theres willl about 1/4th inch of play at the top
autobahnsho
SHO Victim
NY for now, WY for real
Cheater bar! :D
A long section of steel pipe on the end of the wrench helps get some muscle on it.
If the 96 is like the early models, you might have to put a socket on the end of the bolt and use an endwrench on the nut...
If there are threads left under the nut then it isn't fully tightened. On the top you should be able to get an 8 mm wrench to hold the stem. Do not use an impact wrench.
