Help RPM's
bigsho
sterling va usa
When I turn on the heater the RPM's drop. It will run fine sometimes. Other times like it wants to stall out. I reset the idle but still does it. Any thing I should try or something you guys know will fix it. Don't give me any shit but its getting a little cold here. I know not as cold as you guys up north but hay. Thanks
Robbie
95 MTX red
SS SNORKEL
24 and 26 sway bars on floor
Cohiba
Denver, CO USA
Here are a few things I would try: First, when was the last time you cleaned the Idle Air Bypass? If you have not done this lately, you can find instructions at shotimes.com, it's a very simple procedure that has great results. While your cleaning the IAB, you may as well double check the rest of your air intake system for buildup (Check the Throttle Body, Mass Air Flow Unit, and you cold air intake) or blockage. If this doesn't help, take it to your local auto store and have them check the battery, and alternator. I know Checker Auto does this free of charge. It should be one fo these two things, unless you have a problem with the heater core, in which case do a search on the forum to find out what kind of trouble that is.
Yamaha V6 24V DOHC 3.2 Liter SFI
1994 Ford Taurus SHO.
Plus Mods
Click Here For My Website!
Chevivore - Prefers to eat Chevy Vehicles; Normal Diet includes Camaros, Cavaliers, Impala, Malibu, Monte Carlo, occasional Z28 Camaros (although these may bite back!), and lots of RICE every day!
