Help. Replaced cam sensor. didn't work.
Ok, here goes. I recently got this car from a friend. It would die randomly and sometimes not restart right away. I was told by the friend, the Ford mechanic, and a second mechanic that it was the camshaft position sensor. I had that replaced today and on my way home the car still died 3 times. He had it taken to the Ford mechanic and looked at and as far as I know they ran the engine codes and everything. I need to know what other things it could possibly be. It is starting to become more of a pain then it is worth.
Any info would be greatly appreciated.
Also, how to I check the engine codes on my own? Will I have to check after the car dies or with they always show up?
EDIT: My car is a 1995 ATX 3.2L SHO 68k miles. Had 60k tune up before I got it.
Thank you
Thank you
