DemonNeno
SHOCAGO Freak
Hey all
Alright, so i took off the door panel to see what was up with the door automatically unlocking itself when I pull on the outside door handle. (It opens the door, whether or not you locked them...) So I noticed the actuator was moving up and down (not sure if it's supposed to or not). I don't know if that's what it's called, but it is the part that all the linkage from the door handles run to. So i grab onto it and hit the door lock button.. This is where the problem started... There's a bracket on the inner door skin that appears to run to it, well this just FELL off!! The bracket screw was loose... Now, the door still unlocks itself from the outside, but the inside door handle will not work.. It will not move, ti's frozen. Any input?! My door is apart right now.. I can't leave the car like this overnight as someone will most likely ROB the damn thing!
Any input is GREATLY(!!!!) Appreciated!!! THANKS!!
