MO-KAN SHO
Okay, I need input...
Lately, I've noticed the car doesn't shift as smoothly as it used to squint ... Driving it today, It got worse, and now I can't shift into the bottom row of gears. eek! cuss I managed to wiggle into 1st and third, although it wasn't easy, so I got home, but I don't have any way of getting under it safely to check out the shifter hardware. Basicly it feels like the gates all slid toward the back of the car, now when it is in 1st, the shifter is where neutral between 1st and second used to be, and I can't go far enough back to catch 2nd. 4th and reverse are the same.
When the car IS in gear, it drives fine, nice and smoothly, It doesn't buck and grind like my cavalier did when the tranny in it went out, it just feels like there's something wrong with the shifter.
Anyone come across this before??? If not, any ideas at all????
I'm also consulting my helms (which thankfully arrived yesterday!!!) so between this and that, I'm hoping to figure it out. Whether it's a tranny bad, or a bolt missing, I don't care, I just want it fixed!
