Help dismantling front clip
haydenm315
Reisterstown, MD.
For those that don't know, I have an extra engine, transmission, one side of suspension, and a subframe in my garage.
I removed the extra suspension, ypipe, and subframe from my old 94 in the garage. Next I'd like to remove the transmission. I'm using one of the large engine to transmission bolts as one of the strap points. My question is where should I bolt the second strap point on the motor that is strong enough to support the weight of the transmission while I remove it. I read a while back that someone used the head bolt where a manifold to head bracket bolt goes. There is a good bolt on the back of the motor, but it is on the same side of where I have the first strap point on the obvious hook thing. What should I do?
<small>[ July 30, 2003, 07:02 PM: Message edited by: haydenm315 ]</small>
haydenm315
Reisterstown, MD.
There was a bracket that had some pretty beefy bolts on the back of one of the heads. I've got it all seperate now, and can return the cherry picker. I'll probably still buy a video from shonut, but I feel more comfortable knowing that I just dropped a subframe and transmission. The next step is cracking open the transmission. I'll probably save that for when I have the quaife on order.
haydenm315
Reisterstown, MD.
I took some pictures as I was taking everything apart. They can be found at http://compaq.skyline.net/~hayden/sho/blue_sho/
The front with the subframe and tranny still attached
From the side with everything still attached
The front left of my subframe. This hit the jersey wall. I don't think it can be repaired.
Another shot showing the beautiful manifold
The front with the suspension and subframe removed
The side with the subframe removed
The rear with the transmission attached showing the tranny mount
Upon further inspection, this engine is huge! Enjoy the pics.
<small>[ July 31, 2003, 11:24 PM: Message edited by: haydenm315 ]</small>
