Hey guys I really need some help here! My car is driving me crazy! If im going down the road it will steer really funny and the car is all over the place. This all happened after I replaced both balljoints, strut rod bushings and I did the 96 brake upgrade. Both tie rod ends are new as well. The biggest problem is if I hit a patch of snow or a wet sewer drain while going down the road the car slides toward it and its hard to regain control. I checked everything and am still lost! please help!
Well turns out it was a bad aglinnment. But heres the kicker, about a year and a half ago I installed eibachs and sensatracs on the front with NEW mounts. Well when I was done I had two black metal spacers that go right on top of the mounts that I forgot to put in so I searched here and came to think they were just there to reduce noise. Turns out as I removed the nuts for the mounts the studs just fell in, The mounts had mushroommed up into the strut tower itself and ws causing the top of the strut to shift. Just an fyi dont forget those plates!
