heater stuck on
Shobo89
IN
1. The heat is always on, no matter where the temp is set to. I did a search and found nothing on this problem. I can turn the fan off, but heat still finding its way out of the vents. HOT
2. The "bing bing" sound when the door is open should always sound?, even if the keys are out of the ignition? I hate this sound and want to either put some foam around the speaker or take it out of the equation.
3. turn signal will turn on but not modulate/ flash unless I push the lever in the pattern of the blink manually. Whats the deal with this.
Thanks in advance to any answers. Keep me away from the dealer and I will be very happy.
shoRunner
GA
well for the first one, its probably your blower control module. which can be found in a junkyard from any taurus/sable with climate control. you can do a search and get pictures on how to replace it. as for the others i'll let someone else answer those for ya.
projectSHO89
SHOless In St L
1. Blend door actuator, not the blower control module. Not a fun job.
2. Worn out "Key in ignition" switch. You can disconnect a single wire under the steering column to **** this.
3. Worn out multi-function switch.
Steve
