heater core is leaking have a question
edogg23
Buckley, WA
Just did a 60k on my car and now it drops this nice little suprise on me... Anyways I want to try some barrs stop leak first. Here is my question. I know you can bypass the heater core so I was wondering if there would be a way to only run the stop leak though the heatercore by isolating it somehow to keep that crap from clogging up my brand new radiator and waterpump.
_______________________
Erik from Orlando 89 silver SHO 128k miles dynomax cat back w/out resonator, ss y-pipe, ss underdrive pulleys,eibach springs, koni struts, pp motor mounts, 17X8 fitipaldi polaris rims with 245/45/17 zr comp t/a tires SHO FEAR written across the windshield, v1 radar detector quantum tinted windows, custom cold air intake with a ractive heat shield. 14.8 @ 93 mph in 90 degree weather!
89 Gary
Millbury, Ma.
I don't believe you can. Why do you believe it's not good for the radiator or pump? Another fools tale! It may not look pretty but it's no harm for either. Just don't be using more than they recommend-if you have to keep adding some then you will have to fix it the hard way.
edogg23
Buckley, WA
well even though I could not see any leakage to the fire wall I figured I would try tightening them just to see if it would do anything. It didn't... So then I took the clamps off and discovered that one of the clamps was jammed and was acting like it was tightened all the way when it really wasn't I fixed it up and problem solved!!!!
Anyone who thinks they have a heater core leak should definatly try this first!!
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Stop leak is the DEVIL!!
Glad you got it figured out. Replacing the heater core is not my favorite thing to do on a Taurus.
crystizel
