Headlights
Corby
Porsche Eater
I was wondering if there is a local auto parts store where I could pick up a headlight replacement, my front left one is out. I know you can purchase them off of ebay, but I can't wait for it to ship, does anyone know of a store like napa or advance auto parts will have them? I looked at some at advance auto parts, can anyone tell me what kind it is or a part # maybe?? Thanks for any advice.
97SHOgt
Cincinnati, OH
The bulb is out? or the headlight is broken or something? Why don't you just replace the bulb? Maybe I'm missing something, not trying to be an a$$ or anything.
Corby
Porsche Eater
Yea sorry, I meant to say the bulb is out, the headlights are fogged and yellowed, but I'm not to concerned about that, just the bulb is out. I'm not sure which one to get, they have all different sizes and what not.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Even walmart got those.
Corby
Porsche Eater
Funny that you say that.... I was just at walmart, found silverstar bulb, had them install and well, the new one is yellow. I looked on the back of the box and it is suppost to be white. My passenger side one is still white but the new silverstar one is yellow. I'm a little confused here, I asked the guy if he was sure he installed it correctly because its yellow and not white, and he said hes positive. He also said that the old bulb was exploded when he went to replace it. Could this be the reason for it to be yellow or is it just because its a defect light?
97SHOgt
Cincinnati, OH
You can fix the the yellowed headlights with a little TLC. Some wetsanding with two or three different grit sand paper (I did 500, 800, and 1500). Then used Meguiars PlastX to polish it up when I was finished. Turned out great. Should last a couple years I'd think. Cheap fix which will really help. Took me about four hours to do both headlights and foglights. Probably get better results if I took more time. Big improvement regardless.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Depending on the quality i guess , theres some whiter then others.
Make sure its not your yellowish plastic making you think its the bulb thats yellow.
If your budget permits it , buy another one , replace the other not changed bulb , see if both are the same now?
Part as a defect ? , i doupt it , a bulb works - or not.
Cocoa,Florida
people buy the silverstars and return them back to the store with there old bulbs back in the package.this happend to me once.
Corby
Porsche Eater
That light I was talking about is already burned out again, faulty bulb, bad install, voltage problem?
Corby
Porsche Eater
I guess its because moisture in the headlight drips on the bulb and it explodes, that's what the guy told me at least. Would wiping those puppy's and sanding em' down fix the problem?
MoSHO
MISSOURI
i think i saw the headlight assemblies on ebay brand new for like $93 if you decide to replace the assembly
CerberuS
300 HP N/A SHO
Granby, QC, Canada
If you dont have the cash , theres a stickied thread about how to do that (in the cosmetics forum), gives nice results , i tried it.
Corby
Porsche Eater
Just in case anyone was wondering.... there was a nice crack on the plastic casing where you would insert the bulb.... put some sealer over it, problem solved.
The yellow Silverstar may have been due to low voltage. This may be because of a bad connector or bad ground.
