Headlight harness and Sylvania SilverStar Intrest
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
We are looking to start selling headlight harnesses and Sylvania SilverStars at SHOBros.
The headlight harness will give a boost over your worn out old stock ligting system. The bulbs will be brighter over stock. So with this combination you will have a brighter headlight setup.
The headlight harness would be $62.99 and the bulbs $40.00 plus shipping.
If you are interested let us know and this can turn into a group buy if we get enough. Also let us know what Gen and bulbs (9007, 9004)
1. Minnesho
2.
3.
4.
5.
NJSHO
Clean Your Shorts!
NJ
As a note, headlight harnesses work much much better than the stock wiring.
HoustinoJillian
name's JUSTIN
usa
where are you sourcing your harnesses from? i'm in the market for one... but its not for a stock use, i need it to have a 9007 input from the stock wiring, and a 9006 putput as well as a highbeam wire output... for my HID headlights.
Minnesho
i was wrong
MinneSHOta
i'd be interested in one for a second gen, 9007 bulbs. would compliment my perfect headlight housings :thumb:
Corby
Porsche Eater
Are the headlight harness and header panel the same, because if they are I need one.
HoustinoJillian
name's JUSTIN
usa
erm headlight harnesses are wiring, header panel is a piece of the car body...
hawkeye18
Sorta cares
Norfolk, VA
I know the 9007 is stock on SHOs but what other bulbs are possible in that housing? Could you run an H4 in there? Cos that would be suh-weet! Can't afford a harness right now, tho :(
HoustinoJillian
name's JUSTIN
usa
i'm in if you can do a custom one (for a gen 2). i'd need for one end to have a 9007 connector (male like the bulb), and then the other end to have two sets of empty wire ends for low and high beams. i assume that your harnesses would use relays, fuses and be connected directly to the battery (otherwise they wouldn't be an improvement over stock right). anyhow, please PM me if you need more specifics from me, thanks -Justin
a schematic of what i want:
chknhwk
¡Carlos Toraño!
Bakalakadaka St.
1. Minnesho
2. chknhwk
3.
4.
5.
I'm interested...unless we can set something up for some clear lenses and projectors from Depo... :biggrin: I'd rather have some projectors.
LOUDSHO92
Sponsoring Vendor
Yes it still will work.
We are looking into some cheaper pricess for them as we have found some information. They could be custom done.
noSHO4u
Bartlett, IL
RAYJAY said:
will this harness still work with the lamp out function?
Does that mean that the 'lamp out" idiot light will not be on all the time, and only on when one of the bulbs is actually out?
I remember reading on this forum that when using relays for better light output the "lamp out" light was always on and it was something you just have to live with. It had something to do with the current drop of the relay was not the same as a light bulb, so the logic behind the idiot light assumes that the lamps are actually out and warns you about it. Having the lamp out light always on just to get better lgihting would be quite an annoying mod.
This would be a great product if the lamp out light continues to function as it is supposed to.
0V3RC10CK3D
Washington
I'm interested but I'm also new to things, if you can show me a picture or diagram for installation I'm in for the buy, I can't see crap at night.
dan.delargy
